× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
Reply
CM2050V Xfinity cannot activate voice
mcsd4959
After multiple calls with customer service, a tech came out today and still could not get voice to work.  Internet is fine, but voice is a no-go.  Tech called multiple people for assistance but no one could activate the voice.  We ended up putting my old Arris modem back in for voice only and keeping the CM2050V for internet.  It works but it's wonky at best.
This seems wrong...event log posted below. Any ideas?  Thanks in advance.
Message 1 of 5
Guru
Re: CM2050V Xfinity cannot activate voice
the emta log/connection screen would be better. did you have them reprovision it?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 5
mcsd4959
Thanks - new screenshot attached.  I think this is the one you asked for.
I'm not sure exactly what steps were taken but the tech did say he had Xfinity activate the modem repeatedly and nothing worked.  He came up with the idea of using the old modem for voice and worked with Xfinity to make that work so it seemed to me that he knew what he was doing...but I am just a lay person.
Message 3 of 5
owlyn
Guide
The regular tech support people can’t do it. You need to get through to the Xfinity Voice Support department.
Message 4 of 5
Kitsap
Master
Provisioning and activation of the modem is a separate event from provisioning and activation of the eMTA.  When the technician asked to have the modem activated, they missed the mark.  Standard support personnel do not have the tools to deal with the eMTA.  Only the Xfinity Voice Support group has the tools.
My setup: Comcast -> Netgear CM2050V -> Netgear R9000 (Voxel V1.0.4.68HF)
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 294 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
