Orbi WiFi 7 RBE973
Reply
CM500 Blinking Lights
Mikerod72
I had been using a CM400 with my Spectrum internet but in the last month was getting service interruptions more and more frequently so I decided to purchase a CM500 thinking maybe my modem was the issue. Installed the CM500 and now I see a green blinking downstream light along with a solid amber upstream light.
Message 1 of 3
Guru
Re: CM500 Blinking Lights
If you log into your modem, can you post a screen shot of your connections page?
I'd also recommend removing any splitters, amplifiers, 90 degree elbows, extended runs, cheap connections, or kinked cables from you line.
Message 2 of 3
Guru
Have the ISP check the signal and line quality up to the modem from there side.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1607 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
