Orbi WiFi 7 RBE973
Reply
CM700, no wireless settings on login
pjs15
Tutor
Using a Windows 10 computer, using a browser via 192.168.100.1 to access Netgear Genie. INternet service is provided by Comcast.
Once I'm logged in, there is no option for changing the security settings. Under Advanced and Administration, my only options are Modem Status, Set Password, and Event Log.
This happens with Chrome, Internext Explorer, and Firefox.
What do I need to do to access the Security settings so I can make sure the modem is using advanced security features -- or is that something that Comcast handles and I have no access to?
Thanks for any tips.
Model: CM700|High Speed Cable Modem—DOCSIS 3.0
Message 1 of 3
Accepted Solutions
Guru
Re: CM700, no wireless settings on login
The CM700 is a modem only.
There isn't wireles. It isn't a router and doesn't have routing capabilities.
Message 2 of 3
All Replies
Guru
Message 2 of 3
pjs15
Tutor
Thanks, plemans. To quote Homer Simpson: "D'oh!" (hand slaps forehead) I was recalling what I used to see when logging into my Netgear router. Thanks for the reminder.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1294 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
