Orbi WiFi 7 RBE973
Reply
Cable modem router C6220
nah1
Initiate
My router is not showing WiFi anymore. I have reset multiple times. The router itself is on just not the WiFi it won’t show any networks. Please help if you can
Message 1 of 4
Guru
Re: Cable modem router C6220
Are you able to access it wired?
Did the wifi on/off button get hit? push and hold it for 2 seconds.
Message 2 of 4
nah1
Initiate
Sorry for the late reply but yea I didn’t realize there was the on off button. Pressed it and everything worked fine thank you sir
Message 3 of 4
Guru
Glad you got it fixed! You might mark it solved so others aren't still trying to help with the issue
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 422 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
