Orbi WiFi 7 RBE973
Reply
Can I use the Modem CM1200 for 2 routers?
cain38
Follower
So my dad and I use different routers. His is pretty old so I bought one for myself awhile back (Nighthawk R7800). I’ve been connecting mine to his with a Ethernet cable since his is connected to the modem. That modem only has one ethernet port. Been getting by with this situation for awhile but now that I’m fully back from college, I can’t stand the constant ping spikes and freezes when playing games. I was thinking of methods to make this work but I believe just buying a whole new modem entirely could help. Would the NETGEAR Nighthawk Cable Modem CM1200 work for 2 routers? I know it has 4 ports so I just wanted to know if it’ll be what I’m looking for. Or just open to any suggestions too!
Message 1 of 4
microchip8
Master
Re: Can I use the Modem CM1200 for 2 routers?
A modem doesn't care how many routers you hook up after it. Use a small switch to connect to the modem and the 2 routers.
But, the ISP does care how many devices you try to get a public IPv4 address for. Most limit based on MAC address and hand over only 1 address. If you're lucky, like me, you can get IPs for 2 devices.
Routing: NETGEAR RAX43 - Firmware: v1.0.15.128 (1 Gbps down, 40 Mbps up)
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (GS116v2) / 2x NETGEAR PL1000v2
Desktop: AMD Ryzen 9 5900X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 20 TB
Message 2 of 4
Guru
Who's your isp?
Thats the key. mosts ISP's only support 1 public ip address meaning only 1 device can be connected.
But not all have the requirement. so potentially you can. but its contingent on the ISP.
And even if the ISP only supports 1, sometimes you can pay them for extra or for a business class line that will let you.
Or you could look at what modem he currently has and why he's getting ping spikes/lag. the R7800 is a solid router.
so curious where they're coming from.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 4
Guru
Sparklight supports more than one WAN IP.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 335 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
