Orbi WiFi 7 RBE973
Reply
Can't access 192.168.100.1
HenryLeeChi
Hello.
I just got a new modem CM1100 and I can't seem to access 192.168.100.1 on my pc. I can access it perfectly fine on my cellphone though. Default gateway seems to point to my router 192.168.1.1 if that is of any relevance. ISP is WOW. I had the SB6190 modem before and was able to access with that modem but had to get a new modem due to lag spikes.
Any ideas on why I cannot access?
Model: CM1100|Nighthawk Multi-Gig Speed Cable Modem—DOCSIS 3.1
Message 1 of 7
Guru
Re: Can't access 192.168.100.1
What Mfr and model# router do you have connected between the CM modem and PC.
Can you connect to the modem directly with a PC?
Message 2 of 7
HenryLeeChi
 the router is a netgear R7000P. I can connect directly but I still won't be able to access 192.168.100.1. I have already tried unpluging, disconnecting the coax, connecting directly to my pc, and then plugging back in with the coax disconnected. That doesn't allow me in 192.168.100.1 either.
Message 3 of 7
Guru
Press the back reset button for 15 seconds then release.
Message 4 of 7
HenryLeeChi
Just tried that and I still can't log into 192.168.100.1 on my pc
Message 5 of 7
HenryLeeChi
factory reset my modem AND my router and now it seems to work!
Message 6 of 7
Guru
I would either make contact with NG support or get you another modem. Seems like the modem maybe in a bad state.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 4267 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
