Orbi WiFi 7 RBE973
Reply
Cannot connect CM600 to Cox despite a live connection on cable - worked using a Cox modem/router
javarredondo18
Follower
My CM600 is not able to connect to Cox internet. The cable is live with a Cox connection. I had a tech come out, and he confirmed it was live and verified by using a Cox modem/router.
I verified the S/N and MAC with Cox serveral times, but the router is not pushing anything through. They were not able to send a signal to it at all. I went to the default access link and factory reset the modem multiple times through this process with no luck.
Looking for any solutions. The tech mentioned he had seen this before, and it might because my modem was linked to a different ISP before. I called the ISP I had used and they were unable to locate my account from 4+ years ago, so there was no way to check.
Any suggestions? Thanks!
Message 1 of 5
Guru
Re: Cannot connect CM600 to Cox despite a live connection on cable - worked using a Cox modem/router
May need to get into a different modem if the ISP can't associate the CM600 to there system.
Message 2 of 5
Guru
Who was the prior isp?
I've seen an instance or to where the prior ISP's firmware caused issues when the new ISP sent their provisioning. It tends to be an issue with an ISP who only support IPv4 and the new one provisioning using IPv6
Message 3 of 5
Guru
don't remember 100% but i though it was WOW!
Message 4 of 5
vkdelta
NETGEAR Expert
pls provide connection table + DOCSIS Event logs for review
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 896 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
