Orbi WiFi 7 RBE973
Reply
Cannot figure out how to factory reset C3000 router
serialnick
Initiate
This is a wireless n300 router with model number c3000 running on Windows 10. Somehow i've managed to mangle the admin password for router login (note: NOT the wifi password--i'm up and running with no problem but i can't make any changes to router settings).  All the documentation however directs me to login to the router (!) to do anything I would normally do like change the password or do a factory reset.  Some other models i notice have a handy reset button on the back, howeever this model does not.  Any recommendation on how to get past this, or how to do a reset without having to login to router?
Message 1 of 3
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Cannot figure out how to factory reset C3000 router
Hello serialnick
The reset button may be located on the bottom of this modem should be a small pin hole.
DarrenM
Message 2 of 3
All Replies
DarrenM
Hello serialnick
DarrenM
Message 2 of 3
serialnick
Initiate
Right you are!  Thanks!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 13851 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
