- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cant Login Back after C7000v2 reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Had to reset my c7000v2; but after the reset, I cant get into the router/modem. The 192.168.0.1 aaddress is not pinging, I connected a cable to my laptop but it was unable to receive any IP; provided an static IP 192.168.0.222; still no luck. The default NETGEAR24 SSId is also not visisble ..
Appreciate any help in advance.
Ari
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cant Login Back after C7000v2 reset
Pressing the reset button for 15 seconds then release the wire connect the PC to the modems LAN port and open a web browser to 192.168.0.1 or 192.168.100.1 doesn't result in anything?
- Mark as New
- Bookmark
- Subscribe
- Permalink
what are all the lights on it doing?
Try resetting it but unhook the coax from it. unhook coax and push reset for 7-15 seconds while its powered on.
then try going through reset again.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
