Orbi WiFi 7 RBE973
Reply
Cax80 keeps dropping internet connection
BEB7474
Star
Recently purchased Nighthawk CAX80. Never had problems w/ my internet connection before hooking up the Cax80. For last 2 wks since my Cax80 has been connected, im getting disconnected like every 20 min, ethernet & wifi. When I check out my Nighthawk app, it tells me I'm connected. Doesnt tell me I'm disconnected til I try to do a speed test. I've spent hours on the phone w/ NG "expert techs." Thats just been frustrating (language barrier & wait time) & a waste of time. I called Cox cable to make sure everything was good on their end. They said signal & connection are strong. When I lose connection, the lights continue to light like normal. I have only 2 devices connected. My cell & a streaming box. Any advice or help would be great. I read the posts above & I'm wondering if that worked?
Message 1 of 69
Guru
Re: Cax80 keeps dropping internet connection
What firmware is on the router aspect? (the cax80 has firmware for modem and for the router)
Do you have a screen snip of the cable connections page (all of it) and the modem logs? it helps us see if its a line issue.
If you have any coax splitters, amplifiers, or attenuators in line, try it with them removed. Also check the coax for bad/cheap connections, kinked/damaged wire, extended runs, etc.
Message 2 of 69
LindaD100
Initiate
ive recently experienced same issue Ive had my CX80 2months now and all of sudden loses internet This unit WAY too Costly to have this issue Considering returning
Message 3 of 69
Guru
@LindaD100 If you want to start your own thread, we're happy to help.
If you start one include a full description of the issue, your firmware for modem and router, and a screen snip of the cable connections page and the logs.
Message 4 of 69
Ramonabeth
Tutor
I don't see a resolution to this issue.  Did you get a resolution through a support ticket?
Message 5 of 69
Ramonabeth
Tutor
@LindaD100   Did you get a resolution from Tech support?
Message 6 of 69
BEB7474
Star
Thank you for responding. Im not using a splitter or anything extra. I have my streaming box connected via ethernet & phone is connected via wifi. I took a pic of firmware. Not sure where to find modem firmware. Any advice would be great
Message 7 of 69
Guru
do you have a screen snip of the cable connections page and the logs?
Message 8 of 69
Guru
Are you having problems with your CAX80?
Does the entire CAX80 loose internet or just wirless?
Have the ISP check the single on the service line up to the modem.
Be sure there are no coax line splitters in between the modem and ISP service box.
Be sure your using good quality RG6 coax cable.
Message 9 of 69
Lurksalot
Apprentice
Hi,
My Gateway: Nighthawk CAX80, FW V1.1.0.41 - just bought less than 7 days ago.
I am having the same, if not a similar, issue where I get the "connected, no internet" message. I primarily see this on mobile device. But end rebooting the CAX80. This is only impacting the wifi connection as I am hard wired to my work laptop with no issues. I am using a RG6 coax cable. I do not have any splitters, etc.
At the time where I re-attempted to connect to the wifi with the mobile phone I see this in the log;
(I replaced numbers with #)
[DHCP IP: 192.###.#.##] to MAC address dc:bf:e9:a4:eb:2c1Tue Sep 22 08:08:22 2020192.168.1.43:00.0.0.0:0
When the CAX80 works as expected it performs well, but I need to try and resolve this before my return window closes. I have reset to defaults twice in the last few days.
Thanks
Model: Dual Band
Message 10 of 69
Guru
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
@Lurksalot wrote:
Hi,
Thanks
Message 11 of 69
BEB7474
Star
That must be the routine solution "call your ISP check signal blah blah blah." Been there done that. What their own tech told me was, "this is their newest model, so they are working out kinks." Nice, what a waste of $460.
Message 12 of 69
BEB7474
Star
How can I get that? Everything loses connection. I took a screenshot of my internet port settings. My ISP said my signal is very strong. They came out & chkd my connections & said everything was good on their end &my end.
Message 13 of 69
Guru
Post a screen capture from the modems web page under Cable Connections. There could be too much power on the line as well.
My CAX80 has been running great for me. Most issues are ISP and signal on the cable line releated.
@vkdelta
Message 14 of 69
BEB7474
Star
Screen shot of cable connection settings is attached. Ive lived here for 5 yrs & never had a problem, EVER. My At&T wifi worked flawless. I have Cox now & it worked perfect w/ their modem/router.
Message 15 of 69
Guru
You need to get all the info off the connections page. not just the little bit your screen shot had.
Message 16 of 69
Guru
Please include SNR, Power and Correctables:
Mines works great for me, been here 20 years. Though have only had 1 ISP service.
Either the signal line on the ISP is not to spec or you have a faulty CAX and it needs to replaced.
Message 17 of 69
Lurksalot
Apprentice
Hi,
Thanks for your help with this.
I replied earlier in this thread, so I wanted to add that I also have Cox. My CAX80 issue  worsened. Overnight I monitored the connection on a Motorola phone with Wi-Fi 4 ( 802.11n) and starting at about 2:30 am and ending about 3:30 am there were multiple disconnects. My Wi-Fi 6 (AX) client, Surface Pro, did not have this issue. The wifi icon, on the Motorola, displayed with an 'x', which essentially means connected with no internet. I checked the logs and the description was something such as, 'WLAN rejected, incorrect security...'. Throughout the day it has become instable and was no longer giving connectivity to the hard wired laptop. Restarting the modem resolved this, but not a long term solution.
When the CAX80 is working as expected it works great. The Surface Pro speed test was always above the speed plan I subscribe to. In fact, all devices (Wi-Fi 5 / ac) consistently had higher speeds. I'm going to return the CAX80 for a replacement. I want to this thing to work out.
Thanks.
Model: Dual Band
Message 18 of 69
Guru
I would make contact with NG support regarding this.
@vkdelta
@Lurksalot wrote:
Hi,
Thanks.
Message 19 of 69
BEB7474
Star
Hope this helps. Ty
Message 20 of 69
Lurksalot
Apprentice
I have a CAX80 replacment in hand and will set up later this evening using the Nighthawk app. As I recall with the first one, during setup with the app, it attempted to activate with Cox and hung there for roughly 15 - 20 minutes before I stopped it and ended up working with Cox tech support to activate. Is it recommended to activate the router with Cox prior to using the app or let the app perform this task and let it run through the process for however long it wants to take?
Please advise.
Thanks.
Model: Dual Band
Message 21 of 69
Guru
I prefer setup using a pc/laptop.
Message 22 of 69
Guru
I've set up using the app while I'm on the phone with the ISP getting the CAX80 activated. Last time I activated my CM2000, I was online CHAT session with the ISP on a laptop connected to my phones internet.
Please advise.
Thanks.
Message 23 of 69
Lurksalot
Apprentice
Hi,
The setup went fine last night. I actiivated the new CAX80 via laptop before using Nighthawk app to set up the device. I kept all default settings with the exception of 'admin' password and 5 GHz wi-fi name\password. It was working smoothly until shortly after 10 PM when wifi connections dropped to all devices. I checked the Connection Status under Advanced Home->Internet Port, the status color was orange/amber and all values were 0 (zero).  I did not try to hard wire my laptop, as I needed to get to bed. In the middle of the night I checked my 802.11n and a 802.11ac devices and they were still not connected, however after 4:30 am they were  connected once again and still are as of this post. This morning I took a closer look at 'Logs' and 'Event Log'. Under Event Log at 10:03 PM I see 'Resetting the cable modem due to docsDevResetNow', I have attached a screen shot.
What happened here? A web search indicates the router cable modem needs to be rebooted of which I have not done.
As of this post the CAX80 appears to be stable. I'm going continue to leave everything as is until tonight, then I'll make additional tweaks and plug-in a USB storage device.
Model: Dual Band
Message 24 of 69
Lurksalot
Apprentice
Lost wifi connection on all devices, again.
Hard wired laptop and it had connection but could not reach router at www.routerlogin.net only with 192.168.100.1
Cable Connection page looked good
Under Advnaced Home, Internet Port was orange\amber color. For a while Connection Status, properties, i.e. IP Address, Subnet Mask, etc. values were all 0'z (zeo's). They eventually populated after about 30 to 45 minutes and Internet Port turned green.
The CAX80 is unstable at this point. I'm going to hold off on taking it back (again), as I have another 12 days for a refund. Hopefully it stabilizes.
Something just isn't right. I've done all I can as my skills are limited as a consumer. Given the price point on this device I shouldn't need to peform troubleshooting to get it to function properly, however I am willing to.
I am hesitant to work with Netgear tech support as I've not had good experience with them, but will give them another opportunity.
Thank.
Model: Dual Band
Message 25 of 69
Top Contributors
Discussion stats
  • 68 replies
  • 8466 views
  • 46 kudos
  • 10 in conversation
Announcements
Orbi WiFi 7
