- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cm1150v
- Mark as New
- Bookmark
- Subscribe
- Permalink
Cm1150v
The internet worked for one day, but our roku and smart tv’s would not connect, nor will the Xfinity streaming app. Comcast said our brand new modem was bad. So we just got another one, and the google pucks will not work, but we have internet. Comcast said we need a bridge system for them to work.
I really don’t understand this tech stuff. How do we get our google pucks to work with this new modem? There is no phone number to call NETGEAR, even though I’m supposed to be able to call in the first 90 days. Any help for this tech challenged mom would be greatly appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cm1150v
Time to determine if its a modem problem or a router problem.
If you hardwire into the modem, does it work? So:
1. turn off the modem.
2. plug a computer into it
3. Turn modem on. Wait until it fully boots. Usually a couple minutes
4. Does it work? Can you browse the internet? Do you get full speeds?
If so, the modem is working as it should and I'd look at the google router for issues.
All the modem does is provide an ip address to the google wifi router and the router will from there allocate internal ip addresses to your devices. If the modem works when directly connected, its doing its job.
Anytime you change modems, its always good to reset your router back to factory and start fresh. Prior settings can mess things up. Did you do this with the google wifi?
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cm1150v
The CM1150v is a modem only with phone line support. it needs a external wifi router behind it so that your Google devices will connect to the wifi router.
As seen in the Connect a Router section of the installation guide:
http://www.downloads.netgear.com/files/GDC/CM1150V/CM1150V_QSG_EN.pdf
@Hdonnelly wrote:
We have Xfinity internet, and had no problems in the past. We just upgraded to the GB speed, and had to buy a new modem, nighthawk cm1150v. We have the google puck mesh system.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBE973S and SXK30; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
• Yes! WiFi 7 is backwards compatible with other Wifi Devices? Learn more
