Orbi WiFi 7 RBE973
Reply
Cm1200 not connected to smarthome
Azriel
Follower
Purchased smart home with echo dot, SmartThings hub, Honeywell thermostat, ring doorbell, Kwikset smart door lock all connected to a Ruckus ICX 7150-C12P. My X10 is connected to the CM1200 and so is the ICX 7150-C12P. My problem is that it’s not communicating anymore. I’ve power cycled all three units and no comms. ISP has refreshed signals but same problem. Is there something I’m missing?
Model: CM1200|Nighthawk Multi-Gig Speed Cable Modem
Message 1 of 3
antinode
Guru
Re: Cm1200 not connected to smarthome
> [...] My X10 is connected to the CM1200 and so is the ICX 7150-C12P.
   Connect WAN/Internet port of the "X10" (not a model number) router to
the "LAN 1" port of the CM1200.  Connect the switch to a LAN port on the
"X10".
   Visit http://netgear.com/support , put in your modem model number,
and look for Documentation.  Get the User Manual.  Read.  Look for "LAN
ports".  Keep reading.
Message 2 of 3
vkdelta
NETGEAR Expert
Always ONLY connect 1 device behind Cable unless you have multiple IP service from your ISP (which many folks do not have).
CM1200 - > NightHawk X10 -> Ruckus switch --> all the wired devices.
Other 3 ports behind CM1200 should not be used unless you have Multiple IP service from your ISP
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 801 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
