Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cm2000
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-10-15
07:58 AM
2022-10-15
07:58 AM
Cm2000
My nighthawk modem will not stay online I’m not getting any signal to it
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-10-15
08:51 AM
2022-10-15
08:51 AM
Re: Cm2000
Do you have a screensnip of the cable connections page and event logs?
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
Message 2 of 2
Top Contributors
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
Announcements
