- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cm700 and cm500 cox activation issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Escalation fixed the issue. They finally sent a guy out but it still gave me the "Device not activated" message. Then he had to call the isp and get it activated. So, yeah. Tier 1 is useless. Just make them send you a tech to get your service activated. CM700 working just fine. Just need to upgrade my Router/AP because it's bottlenecking my speeds.
Thanks for your help.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cm700 and cm500 cox activation issues
What isp did the CM700 come from?
The new CM500 you bought, was it used? What isp was it on?
Some isp's you aren't able to swap modems between because of the way the isp partitions them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will attempt to call and escalate to tier 2 support. I’ve read that tier 1 is absolutely useless in activation modems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tier 1 is fairly useless. I'd also check all your coax connectors. If you're upload connection isn't good enough, they don't get a return signal.
So direct connect the modem to wherever the cox connection comes in. Make sure there's no splitters, amplifiers, attenuators, or kinked cables in the line.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
