Orbi WiFi 7 RBE973
Reply
Cm700 not connecting to internet
roseexe
My modem randomly stopped working and DOESNT reset, do I have to buy another one?
Model: CM700|High Speed Cable Modem—DOCSIS 3.0
Message 1 of 5
Guru
Re: Cm700 not connecting to internet
What are the led's on it doing?
Are you able to hardwire into the modem directly from a pc/laptop (reboot the modem after connecting)?
try accessing it using 192.168.100.1
Message 2 of 5
roseexe
The LEDS are all green, the power button is the only one solid the rest have been flashing constantly. @plemans
Message 3 of 5
Guru
Are you able to log in to it?
Message 4 of 5
You have posted your message in the section of this community given over to Mobile Routers, Hotspots & Modems. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
These devices are very different from the Mobile Routers, Hotspots & Modems covered here.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1027 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
