Orbi WiFi 7 RBE973
Reply
Compatible Switch with CM1100
johnparker67
Follower
I am looking to buy the CM1100 Cable modem and it has 2 ethernet ports that can be channel bonded. I would like to add a swtich where all my ethernet wires are located and connect the switch to the CM1100 ethernet port. THe manual says not to connect an unmanaged switch to the port so is there a list of ethernet switches I can connect to it? Do I need a non-blocking or a fully managed switch? Thanks!
Model: CM1000|DOCSIS® 3.1
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Compatible Switch with CM1100
You would want a router connected to the CM1100 and then you can connect the switch that you want to that router.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1590 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
