- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ethernet Ports on CM1150V (v2.02.04) Nighthawk
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ethernet Ports on CM1150V (v2.02.04) Nighthawk
Be aware that the CM1150V is on MODEM ONLY. There is no built in router. So you'll need 1 external wifi router on port 1. The other ports are assigned by the ISP if they support such features.
One thing to try is to reboot the CM modem after conneting a device to one of the other ports. This may get an IP address from the ISP automatically. However it may not as some ISPs again will control what IP services get assigned to a multi WAN port modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
unless you have MULTIPLE IP SERVICE, you cannot use ports 2/3/4. Not everyone in Comcast network has this service. Not everyone can purchase it.
if you have LAG, you can do Port 1+2.
Otherwise, you can just use 1 port.
NOTE: This is NOT A ROUTER (IT IS BRIDGED MODEM).
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
