- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Factory Signon and Password don’t work
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have Modem Model C6250. I have used the reset button several times, but each time I try to log in with Admin, password is password, it doesn't work. Now I don't have any internet but my wifi provider has run a test and can see that the modem is on line. I'm going to have to trash the modem and go buy a new one. Please assist. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Factory Signon and Password don’t work
Try resetting the modem by pressing the reset button or 15 seconds with the coax cable disconnected from the modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] I have used the reset button several times, [...]
"used" _how_, exactly? Held down for how long?
> [...] each time I try to log in with Admin, password is password,
"try to log in" how, exactly? Some web browser, on some type of
computer, connected in some way, to something, using some URL or other,
or what?
Did you spell "admin" wrong every time?
> [...] it doesn't work. [...]
"doesn't work" is not a useful problem description. It does not say
what you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
Visit http://netgear.com/support , put in your model number, and
look for Documentation. Get the User Manual (at least). Read. Look
for the LED descriptions and "Troubleshoot". Further reading might not
hurt, either.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
