Orbi WiFi 7 RBE973
Reply
GC110 and WNRL 3500 v2 only 100 mbit speed link
Vamp_ir
Hi
I connect my router WNRL 3500 v2 and switch GC110 but speed link is only 100 mbits,
others computers connect do GC110 have 1000 mbits speed link
Why router with switch cant connect to 1000 mbits. I change manualy port speed to 1000 mbits and duplex mode to full, but this dont gave a result
Message 1 of 8
Guru
Re: GC110 and WNRL 3500 v2 only 100 mbit speed link
Try a different LAN cable. CAT6 is recommended.
Try a different LAN port.
Message 2 of 8
Vamp_ir
I tried, nothing
Message 3 of 8
Guru
Try a different switch to be sure. Possible the routers WAN port is bad.
Message 4 of 8
Vamp_ir
😕 you had rights, first port are broke
Message 5 of 8
Guru
Maybe time for a newer model router. Smiley Wink
Message 6 of 8
Vamp_ir
What you propose 🙂
Message 7 of 8
Guru
R7800 or something similar.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 858 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
