Orbi WiFi 7 RBE973
Reply
GS108PEv3 POE power supply
gil_h
Tutor
Hello,
I wish to buy two netgear managed switches that will be powered up by POE.
The first one is a 5 ports managed swicth named gs105pe, this switch is designed to be powered by a POE and there is no other way.
I want to find another 8 ports switch that will be powered up from the previous switch POE output.
I was looking at the GS108PEv3, that is a managed 8 ports switch, but i cannot find any indication if it can be powered up from POE input instead of the power supply.
Does anyone know if the GS108PEv3 can be powered up from a POE source or any other idea which switch can be powered up from POE (With 8 ports)
Model: GS108PEv3|ProSafe Gigabit Plus switch with PoE
Message 1 of 2
Nodism1125
NETGEAR Expert
Re: GS108PEv3 POE power supply
HI gil_h,
I would recommend to purchase a Smart Managed Pro Switch to powered the GS105PE. Please check GS510TP support page.
Please read the GS105PE FAQs.
https://kb.netgear.com/24423/GS105PE-FAQs
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1051 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
