Orbi WiFi 7 RBE973
Reply
Have internet but no WIFI (model C3700)
llacroix4683
Reset the Netgear C3700 router and have internet (using cable) but no WIFI. Tried to login to the router using https://routerlogin.net but can't login. So ran IPCONFIG and tried to login to the gateway IP address but comes back as insecure site. Went to Chrome setting and allowed insecure sites but that didn't work. Any ideas on how to get the WIFI to work?
Message 1 of 12
Accepted Solutions
Guru
Re: Have internet but no WIFI (model C3700)
Im thinking the router portion of the modem is in some bad state that we can't get it out of.
Last idea to try...look up on how to do a 30-30-30 reset.
If this fails then the modem needs to be replaced.
Message 10 of 12
All Replies
Guru
Try a factory reset by pressing the reset button for 10 seconds then release. Use a ethernet connected PC with the modem and Try MS Edge or Firefox and navigate to 192.168.0.1 or 192.168.1.1. See if you can access the setup wizard and complete it.
Message 2 of 12
Kitsap
Master
Did you accidentally turn off the Wi-Fi radios?
Are the 2.4 GHz and 5 GHz Wi-Fi indicators illuminated?
See attached.
Message 3 of 12
llacroix4683
WIFI radio is on and the 2.4G and 5G lights are on. Can't seem to login to router using Edge or Chrome, says it is insecure site.
Message 4 of 12
Guru
Disconnect the ISP coax cable from the modem. Factory reset by pressing the reset button for 10 seconds then release. Use a ethernet connected PC with the modem and Try MS Edge or Firefox and navigate to 192.168.0.1 or 192.168.1.1. See if you can access the setup wizard and complete it. If you can, then reconnect the ISP coax cable to the modem...
Message 5 of 12
llacroix4683
I tried login to router using Firefox (had tried Edge and Chrome) and it brings me to a Netgear Geni page to change my password, when I do that and click the 'next' button, nothing happens.
Message 6 of 12
Kitsap
Master
It is not a "site".  It is a web page on the router on your local area network.
Accept the advanced exception and connect anyway.
Are you using the IP addresses @FURRYe38 recommended?
Message 7 of 12
Guru
Be sure to clear out all browser caches and any browser saved password profiles for the modem. Try try accessing the modems web page. Be sure you press the reset button for 10 seconds and that you feel a momentary bump when you press the reset button. Try pressing it for 15 seconds as well.
Message 8 of 12
llacroix4683
Thanks for all the help but still can't get to the setup wizard. I used IP address 192.168.0.1, also I disconnected the ISP cable but still not working. I clipped a picture of the web page and attached to this reply. Maybe you'll see something I'm doing wrong.
Message 9 of 12
Guru
Message 10 of 12
llacroix4683
The 30-30-30 reset worked!!!!!
Thanks
Message 11 of 12
Guru
Kewl.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1771 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
