Orbi WiFi 7 RBE973
Reply
Help With Firmware Unbricking!
curtissleeth75
Follower
my wndr 3300 is bricked i think, i upgraded my firmware on it and then the wifi went off and its pwer button just blinks help.
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Help With Firmware Unbricking!
Hello Curtissleeth
Are you able to log into the router at all and see the GUI? If not try and do a factory reset on the back of the modem with a pen and then see if the power button stops flashing then try to log back into the router. hope to hear your feedback
DarrenM
Message 2 of 3
DarrenM
Here is also a article i found about reinstalling the firmware if you cant get into the gui
http://kb.netgear.com/app/answers/detail/a_id/19841/~/reinstall-the-firmware-on-a-router-without-the...
DarrenM
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4008 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
