× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
Reply
Hughesnet Provider
menchod
Follower
Hughesnet Provider
 I did some research on Hughesnet alternate modems. The results indicated that the AC1900v was compatible the the Hughesnet service. I would like to get some inside knowledge on the compatibility, if anyone has considered this before.
Message 1 of 3
Guru
Re: Hughesnet Provider
AC1900 is not a model #.  Need a model# here.
I recommend contacting the ISP to see if they support users owned modems on there network. They will have this information.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 3
Guru
Hughesnet is a satellite internet provider. You need to use one of their gateways but then you can connect a different router/access point to it. Keep in mind, it isn't going to increase your internet speed but it might provide better coverage.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 239 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
