Orbi WiFi 7 RBE973
Reply
I am having the same issues with the same version of the firmware (v1.4.12.2)
Caugheyv
I am having the same issues with the same version of the firmware (v1.4.12.2). When I check for a firmware update it says I have the latest one. I started digging because right now most of my smart devices (google homes, lights, etc) will just disconnect from the WiFi and have to be power cycled to reconnect. Did forcing the new firmware help with your issue? I thought it might be the armor causing the problem so I turned that off today to see if that would help.
Message 1 of 3
Guru
Re: I am having the same issues with the same version of the firmware (v1.4.12.2)
There is newer FW here that you can manually load which is recommended:
https://community.netgear.com/t5/Cable-Modems-Gateways/New-CAX30-Firmware-Version-2-2-1-12-Released/...
Message 2 of 3
Caugheyv
Why are we having to manually update the firmware. That seems silly to me in almost 2024. Thanks for the reply
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 449 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
