× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
Reply
I’m experiencing the same thing with my CAX30
Tnguyen93
I’m experiencing the same thing with my CA30 bought a year ago. It won’t even boardcast wifi can’t see wifi in any device, tried ethernet cable from modem to pc but it won’t work. Tested with old modem wifi + ethernet cable work fine. Just completely dead modem now.
Message 1 of 5
Tnguyen93
Re: Cax30 constant issues
Ethernet port is dead, can’t login to modem how can I downgrade the firmware
Message 2 of 5
Guru
All ports dead? Try other ports and swap LAN cables.
Try a factory reset and setup from scratch.
Do you have wifi connection with the modem? You can send the FW update over wifi if you can connect that way.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 3 of 5
Tnguyen93
No wifi all port dead, no way to get access to the modem
Message 4 of 5
Guru
Re: I’m experiencing the same thing with my CAX30
You'll need to contact NG support and ask for an RMA.
I'd contact the forum moderator on this for there help.
@DarrenM
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 380 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
