Orbi WiFi 7 RBE973
Reply
Intermittent internet connection, model c7000v2
RouterC7000v2
Internet connection drops for 5-50 seconds every now and then, Xfinity suggested checking wifi channel and reconfiguring the modem. Even though the modern is in warranty Netgear is refusing to help as the support warranty is only for 90 days. The problem was there from day 1, it took time to realize that the problem might be with the brand new router. How to resolve the issue?
Message 1 of 6
Guru
Re: Intermittent internet connection, model c7000v2
does the issue happen with wired and wireless device?
Only wireless devices?
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 6
footbal9584
I am having this EXACT same problem and it's not related to the WiFi Router. I switched back to my old ARRIS modem and it is working perfectly fine.
Power levels on all channels ranged from 1-3 dB, no errors in the logs.
My plan is to get another one to test with and if I am having the same problem to try a different brand.
Model: CM700|High Speed Cable Modem—DOCSIS 3.0
Message 3 of 6
RouterC7000v2
Both, with wired and wireless.
Message 4 of 6
Guru
@RouterC7000v2
do you have a screen snip of the cable connections page and the event logs?
Message 5 of 6
RouterC7000v2
No, I have no idea how to generate these.
Update: I changed the channel to 10 from Auto (which was on 11) and it seems fine so far, but I need to monitor for the entire day or two to see if it really resolved the issue.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 604 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
