Orbi WiFi 7 RBE973
Reply
Internet Routinely Cuts Out, Upstream and Downstream LEDs switch to amber
Retired_Member
Not applicable
I moved about two months ago, and got set up with comcast.
Since then, my modem seems to cut out multiple times a day. It doesn't fully reboot, it doesn't seem to lose power or anything, just the connection fails and the upstream and downstream LEDs switch from solid green to amber.
After a minute or two, the lights usually switch back to green and I am able to connect again. Sometimes it takes closer to 10 minutes.
I've talked to comcast and they say the signal is being sent from their end without issue. They told me to contact netgear, but the router is about 3 years old and I don't feel like paying for support at this point.
The device log shows various events happening on a regular basis, but I don't know what any of them mean, and I haven't been able to get any reall explanation either way. I'd post the log information here, but it won't load the page for me to collect the data right now. Multile different warning levels and event names and such. I just don't know how to interpret it.
Mostly I want to know whether my modem is dying. Or if there is something else I can do to fix this.
Model: CM500|16x4 DOCSIS 3.0 Cable Modem
Message 1 of 5
DarrenM
Sr. NETGEAR Moderator
Re: Internet Routinely Cuts Out, Upstream and Downstream LEDs switch to amber
Hello creepsalsa
Are you able to get to the log page to post them?
DarrenM
Message 2 of 5
Retired_Member
Not applicable
ProcedureStatusComment
Acquire Downstream Channel657000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnabledBPI+
IP Provisioning ModeHonor MDDhonorMdd(4)
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM25621657000000 Hz2.8 dBmV38.2 dB106204
2LockedQAM2569585000000 Hz5.1 dBmV39.6 dB00
3LockedQAM25610591000000 Hz5.1 dBmV39.6 dB00
4LockedQAM25611597000000 Hz5.6 dBmV39.9 dB00
5LockedQAM25612603000000 Hz4.7 dBmV39.4 dB00
6LockedQAM25613609000000 Hz4.2 dBmV39.1 dB00
7LockedQAM25614615000000 Hz4.8 dBmV39.4 dB00
8LockedQAM25615621000000 Hz4.5 dBmV39.3 dB00
9LockedQAM25616627000000 Hz4.1 dBmV39.1 dB00
10LockedQAM25617633000000 Hz4 dBmV39 dB00
11LockedQAM25618639000000 Hz3.7 dBmV38.7 dB00
12LockedQAM25619645000000 Hz3.7 dBmV38.8 dB00
13LockedQAM25620651000000 Hz3.6 dBmV38.7 dB00
14LockedQAM25622663000000 Hz3.1 dBmV38.3 dB00
15LockedQAM25623669000000 Hz3.7 dBmV38.7 dB00
16LockedQAM25624675000000 Hz2.9 dBmV37.1 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA15120 Ksym/sec35700000 Hz39 dBmV
2LockedATDMA25120 Ksym/sec29200000 Hz39 dBmV
3LockedATDMA35120 Ksym/sec22700000 Hz38.4 dBmV
4LockedATDMA45120 Ksym/sec16200000 Hz36.7 dBmV
Here's the levels. Some of the logs events I see on a regular basis:
Warning (5)
Dynamic Range Window violation
Critical (3)Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Critical (3)Unicast Ranging Received Abort Response - Re-initializing
Notice (6)
Honoring MDD; IP provisioning mode = IPv6
Also, over the course of 10 minutes earlier today, there are 41 event log entries. It pretty much goes Dynamic Range Window Violation, Unicast Ranging Received Abort Response, Dynamig Range Window violation, Received Response to Broadcase Maintenace Request..., and then just loops those over and over and over.
Message 3 of 5
fossian
I'm seeing the same problems with my C7000 on Comcast. Firmware is version 1.01.23.
The internet routinely cuts out as the OP described.
Here are the usual entries I see in my event logs:
  • Critical (3): SYNC Timing Synchronization failure - Failed to acquire FEC framing;
  • Critical (3): Started Unicast Maintenance Ranging - No Response received - T3 time-out;
  • Critical (3): No Ranging Response received - T3 time-out;
  • Warning (5): Dynamic Range Window violation
  • Critical (3): Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 4 of 5
DarrenM
I see you guys are getting T3 and T4 timeouts which typically is a line issue either from the lines coming to your house or in the area you may want to have your ISP come check out what is going on.
https://volpefirm.com/docsis_timout_descriptions/
DarrenM
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 4745 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
