- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Issue with Modem CM1000 and router working together
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having issue with Modem CM1000, working with Router tplink AAC4000. Initially when I setup the router it was working for about a day. Then it started to cause the modem to basically shut off > no lights on Power, uplink, download , internet. The light for the network showed orange.
If I turn off the router > the modem functions again.
Soon as turn on the router > same thing happens
Below the Modem status and Event logs from the days issue.
Hardware Version 2.02
Firmware Version V6.01.07
Cable Modem Serial Number 4L0592WEA036A
CM certificate Installed
CM MAC 10:0c:6b:c9:37:60
Time | Priority | Description |
2021-02-02, 17:26:06 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: 1 2; New Profile: 1 2 3.;CM-MAC=10:0c:6b:c9:37:60;CMTS-MAC=2c:73:a0:78:01:d3;CM-QOS=1.1;CM-VER=3.1; |
2021-02-02, 16:25:56 | Warning (5) | Dynamic Range Window violation |
2021-02-02, 16:25:56 | Warning (5) | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=10:0c:6b:c9:37:60;CMTS-MAC=2c:73:a0:78:01:d3;CM-QOS=1.1;CM-VER=3.1; |
2021-02-02, 16:25:55 | Warning (5) | Dynamic Range Window violation |
2021-02-02, 16:25:55 | Warning (5) | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=10:0c:6b:c9:37:60;CMTS-MAC=2c:73:a0:78:01:d3;CM-QOS=1.1;CM-VER=3.1; |
2021-02-02, 16:25:55 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=10:0c:6b:c9:37:60;CMTS-MAC=2c:73:a0:78:01:d3;CM-QOS=1.1;CM-VER=3.1; |
2021-02-02, 16:25:50 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=10:0c:6b:c9:37:60;CMTS-MAC=2c:73:a0:78:01:d3;CM-QOS=1.1;CM-VER=3.1; |
2021-02-02, 16:25:45 | Notice (6) | TLV-11 - unrecognized OID;CM-MAC=10:0c:6b:c9:37:60;CMTS-MAC=2c:73:a0:78:01:d3;CM-QOS=1.1;CM-VER=3.1; |
2021-02-02, 16:25:44 | Warning (5) | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=10:0c:6b:c9:37:60;CMTS-MAC=2c:73:a0:78:01:d3;CM-QOS=1.1;CM-VER=3.1; |
Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
Time Not Established | Critical (3) | UCD invalid or channel unusable;CM-MAC=10:0c:6b:c9:37:60;CMTS-MAC=2c:73:a0:78:01:d3;CM-QOS=1.1;CM-VER=3.1; |
Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=10:0c:6b:c9:37:60;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
2021-02-02, 15:52:59 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=10:0c:6b:c9:37:60;CMTS-MAC=2c:73:a0:78:01:d3;CM-QOS=1.1;CM-VER=3.1; |
2021-02-02, 15:52:58 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=10:0c:6b:c9:37:60;CMTS-MAC=2c:73:a0:78:01:d3;CM-QOS=1.1;CM-VER=3.1; |
2021-02-02, 15:26:12 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=10:0c:6b:c9:37:60;CMTS-MAC=2c:73:a0:78:01:d3;CM-QOS=1.1;CM-VER=3.1; |
Time Not Established | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=10:0c:6b:c9:37:60;CMTS-MAC=2c:73:a0:78:01:d3;CM-QOS=1.1;CM-VER=3.1; |
Time Not Established | Critical (3) | DHCP FAILED - Discover sent, no offer received;CM-MAC=10:0c:6b:c9:37:60;CMTS-MAC=2c:73:a0:78:01:d3;CM-QOS=1.1;CM-VER=3.1; |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Issue with Modem CM1000 and router working together
Correction on the Router Model > Archer A20 (US)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a NG router. TP-Link isn't recommended.
Be sure your using good quality LAN cable. CAT6 is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Getting a new Router is not the issue the Archer A20 is new. After researching the errors that the modem was reporting, going to get my ISP to investigate my lines into the house for noise.
Thank you for the response on the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
