Orbi WiFi 7 RBE973
Reply
It keeps showing up with the same settings as before it doesn't want to factory reset
Monoblanco
I am having the same exact problems described and I am also trying to factory reset the router. It keeps showing up with the same settings as before it doesn't want to factory reset. Worst part is I can't seem to make it to the router's settings page. It also doesn't let me connect to the wifi on some of my devices.
Message 1 of 3
Guru
Re: It keeps showing up with the same settings as before it doesn't want to factory reset
What NG product are you referring too?
How are you factory resetting?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RAXE500 and RBKE963; Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 3
Monoblanco
It is a CAX80, I saw the sticky post about it and messaged the appropriate people. I have tried resetting it holding the reset button, doing that while power cycling it, and the erase function in the router settings. I an not sure what exact version number it was because I currently cannot get to the router settings. It was on the lastest because I checked for updates earlier when I could access the router settings.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 268 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
