Orbi WiFi 7 RBE973
Reply
LAGG/LACP dropping protocol 41
att340u
Follower
ISP: Comcast
Experienced this issue on a new CM1200 running firmware 3.02.01 and on a certified refurbished CM1100 running firmware 7.01.01
If I run the modem with LAGG/LACP disabled, protocol 41 (6to4) traffic passes just fine and is seen on the receiving end and returned back.  No issues encapsulting ipv6 within ipv4 traffic.  All ipv4 traffic routes as expected.
If I enable LAGG/LACP in the modem, ipv4 traffic passes fine (and is appropriately balanced across the two physical ports) however protocol 41 is dropped 100%.  The router is sending and encapsulating the traffic as confirmed by tcpdumps on the router, however the tunnel provider confirms zero ipv4 traffic received to even attempt to establish the 6to4 tunnel.  The moment I disable LAGG/LACP in the modem and tunnel re-establishes itself without issue and all is well.
Ideas?  I'm about to return the modem (again).
Thanks.
Model: CM1200|Nighthawk Multi-Gig Speed Cable Modem
Message 1 of 2
Guru
Re: LAGG/LACP dropping protocol 41
I would contact NG support and let them know what your seeing.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode  | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 320 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
