Orbi WiFi 7 RBE973
Reply
Location for Netgear app
CBSOregon
Follower
I've changed downstairs in family room my locations of laptop and desktop after remodeling. Desktop was downstairs hard wired to internet through the NetGear WIFI and a NetGear extender in my shop/office, Now they're switched positions and I'm using WIFI for laptop downstairs (not hard wired) and NetGear WIFI extender for the desktop in shop/office. My desktop did have the NetGear app but was lost during an upgrade on my hard drive.
So my question is which location would be best to download the NetGear App so I can register and do crirical updates?
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 4
Guru
Re: Location for Netgear app
From Windows Store if they have it there.
Be sure to visit the NH app forum as well for help and information:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
Message 2 of 4
Masonlee94
I bought the netgear RX8000 router to pair with my c7000v2 is that even possible
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 3 of 4
antinode
Guru
Re: I bought the netgear RX8000 router to pair with my c7000v2 is that even possible
> even possible
   First, start your own new thread for your own new problem, instead of
diverting this old, unrelated thread.
   Second, when you do that, decide on _which_ model, "RX8000" or
"R8000".  Look for "Model" on the product label.
   Third, what was your actual goal?  _Why_ do you want to "pair" these
devices (whatever that means to you)?
   If your goal was to extend the wireless network coverage of your
C7000v2, then visit http://netgear.com/support , put in your (actual)
model number ("R8000"?), and look for Documentation.  Get the User
Manual.  Read.  Look for "Use the Router as a Wireless Access Point".
   General advice: You might have more success if you described the
actual problem which you are trying to solve, rather than asking how to
implement some particular "solution" (like, say, "pair this gizmo with
that gizmo"), which may have little or nothing to do with the actual
problem (whatever it might be).
   Including a few accurate facts might not hurt, either.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 705 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
