Orbi WiFi 7 RBE973
Reply
Lost of WiFi SSID after reboot
CAX30-Owner
Upon reboot, my CAX30 is losing its WiFi SSID configuration (where I've replaced the factory default WiFi SSIDs with my own). Post reboot the LAN IP/range is the same, but WiFI SSIDs have set themselves back to factory state.
Versions are below.
Hardware VersionV1.01
Firmware VersionV1.4.10.8
Cable Firmware VersionV1.04.05
Other than factory resetting and hoping for the best, any other ideas? Thanks!
Message 1 of 4
Guru
Re: Lost of WiFi SSID after reboot
I would try reinstalling the firmware to it. Maybe somethings corrupt in the firmware.
Did this just start or has it been going on since you bought it?
Is it a new purchase?
Message 2 of 4
CAX30-Owner
Thanks for the idea!
It's a recent new issue. I've had the device for nearly a year, but just in the last couple of weeks this behavior has cropped up. Prior reboots wouldn't lose SSID configuration.
Message 3 of 4
Guru
If the reinstall doesn't help, you could try downgrading the firmware a version.
Maybe something in the latest update is causing issues.
You could also try a factory reset after reinstalling the firmware. Maybe something in the settings is actually corrupt causing it. And the firmware reinstall would only fix a corrupt firmware issue
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1103 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
