Orbi WiFi 7 RBE973
Reply
MODEM ROUTER EASILY GETS HOT
Recario
Follower
The Modem gets HOT easily after it was turned on. like 10 minutes the top surface is already hot. is this normal or the unit is deffective?
Model: C6220|DOCSIS 3.0 High Speed WiFi Cable Modem Router
Message 1 of 5
Guru
Re: MODEM ROUTER EASILY GETS HOT
Most modem/router combo units do get warm.
To verify how hot its' getting, you'd need to get you a laser temp guage and see how hot it's getting. Then look at the spec sheet to see the temp range that is set for this modem.
Be sure the modem is in a well ventilated room. You can always place a laptop fan cooler under the modem to help keep the modem cool. Something I always do with my gateway modem I use.
Message 2 of 5
antinode
Guru
> [...] HOT [...]
   Define "HOT".
   Hard to say, without knowing what "this" is.
   If the thing works (for many years), then it might be normal.
   If you're worried about it, then I'd complain to Netgear support
while the warranty is still in effect.
> guage [...]
   Or any suitable thermometer.
> [...] Then look at the spec sheet to see the temp range that is set
> for this modem.
   I've never seen a "spec sheet" which mentions the case temperature of
a device like this.  Has anyone?
Message 3 of 5
Guru
Technical specifications:
Feature Description
Network protocol and standards compatibility
Data and routing protocols: TCP/IP, DHCP server and client, DNS relay, NAT
(many-to-one), and TFTP client
Power adapter • North America: 120V, 60 Hz, input
• All regions (output): 12 VDC @ 2.5A output 30W maximum
Physical specifications • Dimensions: 9.25 x 6.1 x 2.25 in. (235 x 155 x 57 mm)
• Weight: 0.95 lb (0.44 kg)
Environmental • Operating temperature: 32° to 113°F (0° to 45°C)
• Operating humidity: 90% maximum relative humidity, noncondensing
• Electromagnetic emissions: Meets requirements of: FCC Part 15 Class B.
Interface Local: 10BASE-T, 100/1000BASE-Tx, RJ-45
802.11ac/a/n/g/b
Internet: DOCSIS 3.0. Downward compatible with DOCSIS 2.0, 1.1 and 1.0
Message 4 of 5
antinode
Guru
> Technical specifications: [...]
   So?  Please, help me out.  I see no "case temperature" there.  "Case"
and "Environmental" are spelled differently for a reason.  For any
simple device which consumes power, I'd expect its case temperature to
exceed the ambient temperature.
   Great animated icon, though.  Love the useless "My Setup" info, too.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 4764 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
