Orbi WiFi 7 RBE973
Reply
Modem Issue
bwright2
Follower
Modem Issue
Having issue after moving to new house where wireless devices say No Internet for our router/modem yet Xfinity says the connection looks good. Bought another modem and had the same issue. Xfinity says it has to be a setting on the modem. Stuck with their provided modem and that works, but that is a monthly fee which I'd like to avoid. Anyone have a similar experience or know what could be causing this? Thanks.
Message 1 of 5
Failedcm1150v
Re: Modem Issue
I just bought a cm1150v. Won’t buy a 2nd Netgear product that’s for sure . This modem won’t work with Comcast. Zero support
Message 2 of 5
Failedcm1150v
Re: Modem Issue
Op, Get an ARRIS T25 for Comcast. It worked with little effort.. You only get 2 Ethernet 1 gig ports but at least it’s compatible and u own it .
Message 3 of 5
Guru
Re: Modem Issue
Any progress on this?
What model modem do you have? A C or CM series modem?
Message 4 of 5
vkdelta
NETGEAR Expert
Re: Modem Issue
@Failedcm1150v
Can you please provide more details?
you could not activate it?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 597 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
