Orbi WiFi 7 RBE973
Reply
Modem keeps dropping connection
lxstasy04
I keep having problems with it randomly dropping and won’t come back up unless I reboot it. I have been fighting this for a while. ISP says nothing is wrong on there end. I’m at wits end with this so any help would be greatly appreciated. Here is the event logs from the modem.
Time Priority Description
1970-1-1, 00:01:06 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:01:12 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:01:25 Critical (3) DHCP FAILED - Discover sent, no offer received;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:20 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:23 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:25 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:44 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:01:01 Critical (3) No UCDs Received - Timeout;;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:01:02 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:01:10 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.0;CM-VER=3.0;
2019-9-10, 08:51:46 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 09:03:24 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 09:04:28 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 10:16:05 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 10:16:35 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 10:16:37 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 11:20:06 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 15:53:06 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 16:17:17 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 19:54:29 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 19:55:01 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 19:56:06 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 21:58:51 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 22:19:16 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 22:19:21 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 22:19:48 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 23:01:12 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 23:01:44 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 23:02:48 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 23:34:29 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 23:34:30 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-10, 23:35:02 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-11, 06:17:31 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
1970-1-1, 00:00:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
1970-1-1, 00:00:32 Notice (6) Honoring MDD; IP provisioning mode = IPv4
1970-1-1, 00:00:34 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.0;CM-VER=3.0;
2019-9-11, 06:53:11 Notice (6) TLV-11 - unrecognized OID;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-11, 06:53:18 Error (4) Improper Configuration File CVC Format
2019-9-11, 06:53:59 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
2019-9-11, 07:04:55 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=28:80:88:bc:0d:00;CMTS-MAC=00:c1:b1:61:06:3f;CM-QOS=1.1;CM-VER=3.0;
Model: CM500|16x4 DOCSIS 3.0 Cable Modem
Message 1 of 9
Guru
Re: Modem keeps dropping connection
Can you get a screen snip of your connectins page that includes both downstream and upstream power levels and info?
A lot of your errors tend to be signal errors. That screen snip can help out a lot.
A couple things you can do to try to help with it.
1. remove splitters from the lines
2. remove any 90 degree elbows from line
3. remove any amplifiers from the line
4. Try to connect the modem directly where the line comes into the house and test from there.
5. Inspect your cables. water damage to a cable or even water within a cable can cause errors. check for cheap connections, damaged cables, bent (kinked) cables. Replace these.
Message 2 of 9
lxstasy04
The modem is in the basement of a 3 story town house and it is hooked to the line that comes from directly outside. There are no splitters or amplifiers in there. Here is a screenshot of the down and up
Message 3 of 9
Guru
What ISP are you using?
the cm500 is a 16x4 modem. Not sure if this is true for all isp's firmware but in my experience if there isn't all the channels to lock for the modem, they still show but not as locked. Yours is only showing as a 8x3?
Message 4 of 9
lxstasy04
I am using Shentel in northern va. I have a 150mbps down and 10 up. Not sure how many channels supposed to have. Is there anyway I can find out?
Message 5 of 9
Guru
I don't see the CM500 as even a supported modem for your network. Here's their list of supported devices.
https://www.shentel.com/cable-east/support/guides/modem_list
Message 6 of 9
lxstasy04
Yea I had a arris that was doing the same thing as this one. I picked this up just to test to see if it would do the same thing and it does. I call the isp and they set it up and said it was good to go.
Message 7 of 9
Guru
If you've got 2 modems doing the same thing, it tends to point back to the ISP. I know you've been arguing with them about it. Not sure what else they expect you to do if you've replaced the modem and are still having issues. It kind of points back to their line
Message 8 of 9
lxstasy04
That’s what I been trying to tell them. Thanks for all the help I appreciate it
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 3603 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
