Orbi WiFi 7 RBE973
Reply
Moden LED LAN Lights
Bob5545
Why on my Cable Modem is my LAN 2 light blinking green, and the LAN 1 light is off.
I only have two of these on these Modem, why not four, one for each port?
Comments,
Thanks
Message 1 of 3
Kitsap
Master
Re: Moden LED LAN Lights
Two key pieces of information would be very helpful.  What is the model number of your modem?  Who is your internet service provider?
My setup: Xfinity -> Netgear CM2050V -> Netgear R9000 (Voxel V1.0.4.71.1HF)
Message 2 of 3
Guru
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 319 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
