Orbi WiFi 7 RBE973
Reply
N450 CG3000DV2 - odd problem
wyldemusick
I've been using this product since the end of March 2014, and it's consistently had an issue where it does a reset and drops the Internet signal for about 45 seconds while it cycles. This happens every six to twelve hours, and the resets register on the head end equipment (I spent half an hour talking to a tech about this and other things, prompted by Cox going down for a while in my area.)
Is there any explanation for this, or should I just arrange to have the gateway exchanged for another (it was a purchase, but it's still inside the warranty period)?
Message 1 of 5
wyldemusick
Re: N450 CG3000DV2 - odd problem
Digging around a bit, I find that the resetting is apparently an over-enthusiastic DHCP renewal cycle -- ever five hours or so. I don't know if this is common to every one of this model.
WiFi sometimes blips briefly too. Causes tons of fun with the dlna setup when it happens.
Message 2 of 5
wyldemusick
Anyone? Yo! There be silence in here....
Message 3 of 5
Mars Mug
Virtuoso
You are most likely seeing an absence of replies because your modem/router is made specifically for ISPs and there is little public information about it, I’m not even sure if Netgear Tech Support will offer support advice.
Does the router have any logs that you can look at? DHCP issues sound like the most likely cause, and should be easy to identify from a log. If it is DHCP then there’s little that can be done short of a firmware change. Do you know if your public IP address changes very often? If not then you should have the option to set your WAN (public) IP to a static value, and in doing that your next failure will be when the WAN IP actually changes, at which point you will lose your internet connection completely. If you are able to do that as a test it might help in isolating the cause, and you can then set the router back to WAN DHCP afterwards so that it regains its Internet connection.
Just found the manual https://www.timewarnercable.com/content/dam/residential/pdfs/support/internet/buy-or-lease-your-mode... A static WAN IP might not be an option.
That event log image on page 31 looks interesting considering it shows DHCP errors at the kind of intervals you describe.
Message 4 of 5
alittleslow
Novice
Does anyone know how to setup a guest network on the cg3000dv2 ? :eek:
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 5614 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
