Orbi WiFi 7 RBE973
Reply
NETGEAR ORBI CBK40 vs CBR40
kkcole1965
Follower
What is the difference between the Orbi CBK40 and the CBR40?  Also, are either one compatible with Optimum?
Thanks!
Message 1 of 3
Re: NETGEAR ORBI CBK40 vs CBR40
CBK = CBR40 router plus RBS40 satellites.
Thanks!
Optimum what? A modem of some sort? Make and model?
Message 2 of 3
Guru
You'll need to contact Optimum ISP to see if they officially support the CBR40 system with there services since the CBR is a modem with a built in router and wifi system.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 317 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
