Orbi WiFi 7 RBE973
Reply
NETGEAR05 WAP - C7000 Nighthawk
Kefisher
Hi all,
There is a wireless access point showing-up on my wireless network broadcasting with the ssd NETGEAR05. I can't access it (don't know the password), and although it is listed in the WAP chart on the routher, there doesn't seem to be any way to configure it.
Anyone know what this is?
Thanks.
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 5
DarrenM
Sr. NETGEAR Moderator
Re: NETGEAR05 WAP - C7000 Nighthawk
Have you checked if its the name of the guest network?
DarrenM
Message 2 of 5
Kefisher
Good thought but I didn’t because I do have a guest network set-up with another id. Was wondering if it might ne associated with my Comcast cable tv service...i know comcast broadcasts a “free” wifi hotspot.
Message 3 of 5
DarrenM
That shouldn't happen with a netgear modem/router. Do you have any close neighbors could be a signal from there router.
DarrenM
Message 4 of 5
Kefisher
That’s possible, but then again would a neighbor’s access point show-up in my config settings? No other nearby wifi does.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1681 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
