Orbi WiFi 7 RBE973
Reply
Need to change MAC address on NETGEAR Nighthawk C7800
epochdad
I left an open email relay on my machine and of course it was exploited and now my static IP is listed in sorbs and spamhaus.  I have begged them to delist my IP but they said they can't and I have to contact comcast.  I contacted comcast and they wont issue me a new IP address.  I am unable to access many forums due to this problem and I was curious to know if there's a way to "spoof" the MAC address so my static IP will change?
I've tried unplugging the router for a full 24+ hours to see if the IP would change it did not.
Model: C7800|Nighthawk X4S-AC3200 WiFi Cable Modem Router
Message 1 of 7
Accepted Solutions
Guru
Re: Need to change MAC address on NETGEAR Nighthawk C7800
Netgear has set up a community forum specifically for the Cable Modem products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
Message 2 of 7
All Replies
Guru
Thank you.
Message 2 of 7
Guru
Any progress on this?
Message 3 of 7
epochdad
You can close it or even delete it  if you want, I went to the other forum like you suggested.
Message 4 of 7
Guru
Did you find any information?
Message 5 of 7
epochdad
Unfortunately not.  "MAC address is hardcoded with no option to spoof it"
In a hacker forum someone suggested to use Open WRT for firmware to have control over this.
Message 6 of 7
Guru
You'll need a OpenWRT supporting router to do that. Most modems are not supporting of 3rd party FW.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2179 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
