- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear 1200CM modem and I cannot connect to my playstaton 4 pro with ethernet cable
- Mark as New
- Bookmark
- Subscribe
- Permalink
I purchased the Netgear 1200CM Modem to connect to PS4 Pro with Ethernet cable and not working.
I have good wifi. times out for the IP address everytime.
Pleae help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear 1200CM modem and I cannot connect to my playstaton 4 pro with ethernet cable
> I purchased the Netgear 1200CM Modem [...]
"CM1200"?
> [...] to connect to PS4 Pro with Ethernet cable and not working.
Which kind of "not working" is this? As usual, showing actual
actions (commands) with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
What, exactly, did you connect to what, exactly? (Hint: If a device
has different types of Ethernet ports, then "connected to device" is not
enough detail.)
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Pay particular
attention to what the User Manual says about how to use its "LAN ports".
(And, what it doesn't say.)
"wifi" suggests that you have a wireless router. You should probably
connect your (unspecified) router (WAN/Internet port) to "LAN 1 port"
on the CM1200. And connect nothing else to the CM1200 LAN ports.
Connect your client devices to your (unspecified) router (LAN ports).
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
