- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear C6220 router has slow speeds
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you know what may be causing this? I've been able to duplicate this pretty consistently. If I can't get this to work the way it should, I'm considering getting rid of the router.
Thanks!
Ryan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear C6220 router has slow speeds
You're posting in the wrong forum for this device. Here's the correct one.
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
When you redo this in the correct forum (as there's better help there) try to include these details.
Who's your isp?
How are you testing speeds? Aka device used, wifi/ethernet, website used
Its always recommended for speedtesting to be done over a hardwired connection as wireless can have a multitude of other issues.
A screen shot of your connections page (upload and download) and your logs. These help figure out if your connection coming into the house is good.
make sure to remove any splitters, amplifiers, elbows, and to check your cables for poor connections, bends, water damage. Poor signal can impact speeds greatly and these are some of the most common reasons for poor signal.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
