× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
Reply
Netgear C7000v2 Wireless Protocol
CathyCAPS
Follower
I have a Netgear V7000v2 and cannot find information on whether it is 802.11 a/ac/b/g/n?   Can anyone help?
Message 1 of 2
Guru
Re: Netgear C7000v2 Wireless Protocol
There's a support site with access to manuals, firmware, install guides, etc. Look at the spec sheet.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
And yes it's supporting I believe.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 95 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
