× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
× NETGEAR would like to hear from you about specific features so we can improve your experience. To participate in this survey please click HERE.
Reply
Netgear C7100V
AnnBoat
Netgear C7100V
I just purchased this item.
1. I can't get the voice to work. The like flickers on the WiFi cable modem router, then goes off.  So, I don't the use of my phone.
2. I can no longer use my Xfinity streaming on my TVs. The WiFi connects to the TVs but won't stream any channels from Xfinity.
I uninstall the Xfinity Beta and reinstalled it, streaming services for Xfinity still does not work, but I can watch Netflix and Prime Videos. I can no longer watch local channels, either. I signed online to the Xfinity website and shows that it can not connect to my devices (TVs and phone).
Any suggestions
By the way I am not that computer literate.
Message 1 of 4
Guru
Re: Netgear C7100V
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly. ISP will have to ensure the phone services and phone lines are working properly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Routerand RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700, EX7500/EX7700
Message 2 of 4
AnnBoat
Re: Netgear C7100V
Thank you
It is now working.
Message 3 of 4
Guru
Re: Netgear C7100V
Any idea of what helped to make it work now?
@AnnBoat wrote:
Thank you
It is now working.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 274 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
