Orbi WiFi 7 RBE973
Reply
Netgear Cable Modem C7000v2 dropping connection with Xfinity
TKR01
Follower
I have a new router/modem (C7000v2), with Xfinity, that drops connection constantly  for only a few minutes - between 4 and 7 minutes each time. It happens at least 5 times a day, and all devices are affected, so it is either the service or the router/modem. I have rebooted and it still occurs.
Any suggestions? When calling AT&T, I am told they can't assist as I am not using their equipment.
Thanks in advance - Terri
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 2
Guru
Re: Netgear Cable Modem C7000v2 dropping connection with Xfinity
Are you with att or xfinity? you put both on there?
Log into the cable connections page and post that back here with the logs. That can help.
Also, if you have any splitters, attenuators, amplifiers in line, remove them.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 606 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
