- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear DGN2200v3
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear DGN2200v3
I've upgraded my internet speed from 15 Mbps to 50 Mbps, but the max. speed I'm getting is still 15 Mbps. I've called my ISP and they told me my router doesn't support VDSL so unless I buy a new router, the max. speed I'll get is 15 Mbps. Is this true? Does my router only support max speed of 15 Mbps?
Any help would be greatly appreciated. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear DGN2200v3
Please post about this in the DSL Modem forum:
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] I've called my ISP and they told me my router doesn't support
If your ISP's 50Mb/s service uses VDSL, then the ADSL[2+] modem in
your DGN2200v3 will not be able to reach that speed.
> [...] Is this true? [...]
I'd say so.
> [...] Does my router only support max speed of 15 Mbps?
It does over its DSL interface. You should be able to get higher
speeds within your (wired) LAN, but even there, the DGN2200v3 Ethernet
ports are limited to 100Mb/s. (Newer/better devices would typically
have 1000Mb/s Ethernet ports.)
Visit http://netgear.com/support , put in your model number,
and look for Documentation. Get the User Manual. Read. Look for
"Specifications".
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
