Orbi WiFi 7 RBE973
Reply
Netgear Genie C7000 - recover password questions not accepting answers
aspenkay
Follower
I am able to login to my Netgear genie until I get to the Router Password Reset.  It will not accept the answers to the questions.  How can I get passed this section?
Thanks!
Message 1 of 2
Guru
Re: Netgear Genie C7000 - recover password questions not accepting answers
There's a bug with the password recovery.
what it is? if you didn't setup recovery, it still asks the questions. But there isn't a correct answer.
Or if you set it up and dont know the answers or type them wrong (case sensitive) then they don't work either.
so if your answers aren't correct and you don't know the login info, to get back in, you'd need to factory reset the modem/router combo device and re-install it.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 519 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
