Orbi WiFi 7 RBE973
Reply
New AC1750 WiFi cable modem router not connecting to new Firestick
Hoppa007
Tutor
I have a new 4K Fire Stick but it will not connect to my router. First attempt says "error, try again". Retry stays locked in connecting mode. Anyone else having this issue?
Message 1 of 6
Accepted Solutions
Guru
Re: New AC1750 WiFi cable modem router not connecting to new Firestick
Glad you got it working. Thanks for sharing the information. Please mark your thread as solved so others will know.
Enjoy. Smiley Wink
Message 6 of 6
All Replies
Guru
Disable WPA on the modem temporarily. Try to connect your device. Does it connect at all? Then go back and set WPA2 and AES only on the modem. Try to connect the device again.
Is this the only device having problems connecting?
Message 2 of 6
Hoppa007
Tutor
Nope. No error message but now Stuck in connecting mode
Message 3 of 6
Guru
I would get ahold of Amazon for help and information about the device.
Message 4 of 6
Hoppa007
Tutor
Problem corrected. I had to go into "advanced settings" and allow all devices to connect. This is with security enabled. Hope this helps someone else.
Message 5 of 6
Guru
Enjoy. Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1402 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
