- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New CM600 modem consistently gets slower speeds than Xfinity modem (on singlethreaded speed tests)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I recently bought the CM600 cable modem hoping to cut out the modem rental that Comcast provides. I had their Xfinity Technicolor TC8305c modem previously. I have Blast! internet service that provides a max speed of 150mbps. After testing both modems, the new Netgear modem doesn't seem to keep up on singe threaded speed tests such as the one at http://speedof.me
Here are the details (average speeds):
Xfinity Modem
speedtest.net (multi) - 180 mbps
speedof.me (single) - 120-130 mbps
Netgear CM600
speedtest.net (multi) - 160 mbps
speedof.me (single) - 90 mbps
I've also ran several other tests where the netgear doesn't quite keep up.
The modem is updated to the latest firmware (V1.01.09) and seems to work well otherwise. I'm trying to decide if I should ignore this discrepancy or if there is an actual issue here. It's really bothering me though, so hopefully someone has some insight into what could be going on.
Thanks for any help someone can offer!
Below is the cable connection data from the modem:
Frequency start Value | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New CM600 modem consistently gets slower speeds than Xfinity modem (on singlethreaded speed t...
Hello dsuse
Do you happen to have some kind of cable spliter if so try removing it. Sometimes it can cause issues on some modem and other can work just fine with it.
DarrenM
User | Count |
15 | |
8 | |
7 | |
6 | |
2 |
