Orbi WiFi 7 RBE973
Reply
Nighhawk, C6900 WiFi Cable Modem Router
lilpuu
Question on selecting which wifi I should select. On one channel I have a Netgear 5G and the other Netgear15-5G. Is it possible to change wifi from Netgear 15 to Netgear 15-5 without un-installing the product and reinstalling in order to switch? And what is the main difference of having 15 verus 15-5G. Is there an advantage.
Thank you in advance
Message 1 of 4
Guru
Re: Nighhawk, C6900 WiFi Cable Modem Router
Using the modems web page with a browser you an change the wifi SSID name to be anything for each radio. Doesn't have to be the default SSID name that comes with the modem. Change it to your liking.
Message 2 of 4
lilpuu
It's not the name I want to change, it is the wifi settings. If the 15-5 g is faster or stronger, I would like to switch to it instead of staying with the 15g.
Message 3 of 4
Guru
You have to set you devices to connect to either wifi SSID name is all.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 842 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
